Is it possible to compare with WinCC
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all,
Does anyone know whether its possible to "compare" an offline WinCC project with one thats on a touchscreen?
Also, is it possible to upload from a touchscreen with WinCC or is it the same as Protool in that it needs a .pdz file loaded on to flash to be able to upload?
Many thanks
No comparison
I'm asuming you are talking about WinCC Flexible. Most things from ProTOOL are aplicable to WinCC Flexible, including no comparison and that you have to enable retrieve function to be able to recover the program from an OP. You can always recober the executable file, but It can't be modified.
Sincerely,
Kelkoon
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
248
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
369
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
202
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
848
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
302
