Is it possible to give comment to a boolean variable opened from a DB....Siemens PLC
drspanda
Oct 2005
Damanjodi
155
Dear All,
I have a FB where I have opened a DB in it...I want to give comments to the variables (BOOL) which are used in the FB..
For example:
OPN #burner_DB
A(
O #pb_br
O DBX 0.1
FP #fl_pb_1
= #pb_on_shot
I want to give a symbol/comment on DBX 0.1...is it possible is step 7?
No, I'm afraid not. The best you can do is add a comment after the instruction:
A DBX1.0 //This is a start button
edit: Something else you could do if scan time is not an issue is pass this bit to a local variable, use the local variable symbollically, and then pass it back at the end of the function:
A DBX1.0
= #StartButton
A #StartButton
= DBX1.0
Pass the boolean in as a parameter to the FB, the parameter will have a name. When passing in the parameter, use DB1.DBX0.1 (for example) which can also be given a name when declaring it in the DB.
If you put a name on the DBX you can change your code,save it and to display it correcly. Delete OPN #Burner_DB and where you want to use the bool, type it as Burner_DB.WhateverDBX
The comment and absolute address will display to the right if it is selected in "Options"
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
247
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
365
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
197
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
845
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
300
