Is this possible?
Preeya
Nov 2003
112
I have a high speed solenoid valve that I need to connect to a siemens S7-222 PLC... The valve requires a high voltage trigger (48V for 3ms) to open and 24V to sustain. What is the simple way to do this?
Should I use 2 PLC outputs with separate relays and have one connected to 24V and another to 48V supply? The relay connected to 48V will only be ON for 3 ms? Is this possible??
Thanks!
Try this maybe!
We do a very similar thing with some sprayer solenoid valves. These valves call for quick turn on/off times, also in the milliseconds.
The Pull-In Voltage is rated at 48VDC (unregulated) and a maixmum of 200mA @ 24VDC Hold-in.
These are SENCON drivers for can production.
Part # of the driver we use is:
D.I. SOL DRV. LST
213-10563-00
You will also need a rack for this driver, but I do not have that number handy.
Hope this may be of some use to you. :site:
This is old, but so am I.
Preeya,
Here is a starting point, and it was for multiple units purchased, so there may have been a price break. I found an old P.O.
Aug.2001
CARDCAGE..(rack)...Part #213-40375-00....$225
DI Drivers.........Part #213-10563-00....$292
Power Supplies.....Part #213-40378-00....$125
Phoenix Connect....Part #664-12005-00....$ 8
Phoenix Connect....Part #664-12005-01....$ 8
In July, 2003 that same Driver cost $307.
For what we use them for, and the service from Sencon, they are worth the money.
We turn them on/off 280-300 times a minute, usually 7 days a week, 24 hours a day.
Good Luck beerchug
If there is anything else, let me know. This site rules! :site:
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
249
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
370
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
203
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
850
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
302
