ISA 5.1 Refresher - Analog Position Feedback (P&ID Tag)
kdcui
Dec 2007
USA
386
It's been a long time since I've had to think of P&ID tag nomenclature myself (and not gone along with some scheme devised by someone else). I've inherited a P&ID and need to make updates.
Could someone refresh me on what an appropriate tag name would be for position feedback? In this case, analog 4-20mA from a valve actuator.
In my case, the valve has a asset prefix then "-PCV-01". Technically I should have PY-01 or something for the output command but the P&ID has a very minimalist approach and are referring to it as PCV-01...
Would I use something like ZT (position transmitter)?
Would it make sense to append this (such as PCV-01-ZIT) or have a stand-alone tag?
The issue is that we re-use the number of the instrument (there is a PIT01, PCV01, TE01, etc.) so if I used ZIT-01 on it's own, there is ambiguity at to which device it corresponds with.
In a previous life we had something like XV01-ZSC and XV01-ZSO for limit switch feedback (rather than separate tags independent of the XV for the limit switches).
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
81
Dear Fellows; Good day. Here i share two images one is PLC Sweep Time control and Monitor Screen and the other one PID Control Screen. First i...
242
Does anyone have a library of the ISA standard process symbols in PNG, BMP or something that is importable into an HMI screen? I'm about to sit...
1,002
Good day all, A quick question... Is anyone on this forum ISA CAP certified? If so is it worth getting the certification? I've been in the...
1,320
I'm going to start a project for work that will be time consuming over the next year or so. It happens to be a rental unit, so I'm not...
1,302
