Ishida RS-232C ASCII to Compact Logix
KristienP
Jan 2015
Nova Scotia
44
I'm looking to extract the Weight from an Ishida DACS-G back to a Compact Logix PLC. I'm currently looking at two options, the 1769-ASCII module or the RTA 435NBX.
According the info I have (see attached PDF), the message breaks down into 15 HEX values.
[1] = Header, [2] = Command, [3] = Result, [4] to [11] Weight, [12] = Unit, [13] to [14] = BCC, [15] = Footer.
How difficult will this be to read into the PLC and then extract the Weight into a INT/Float value in the PLC, which could then be read from FTView / Historian?
I've never had to work with ASCII before.. Thanks in advance!
Hello Kristien!
I have a problem identical to yours and I couldn't get support from Ishida to solve it, were you able to communicate with the CompactLogix PLC?
If yes, could you share more information with me, please?
Thanks in advance!
Good Afternoon , I'm sure there are many Ishida Muti-Head Weigh Systems . We have a Ishida CCW-M-214W Multi-Head system . We are...
593
Good Morning , We have a Ishida Multi-Head Scale . I had experiece with them for chips , crackers , etc. , but now we are using them for...
485
I was asked to pull data from a Ishida Checkweigher and I have a prosoft mvi-mnet and a plx31.On the plx31 i can only get to to pull 1 read and...
430
Does anyone have any resources that may give specifics about the RS232 protocol from an Ishida DACS-CW? I'm going to most likely use a Comtrl...
3,658
Old plc is a SLC 5 with a 1777-KE talking to WHITE BOX "seemingly serialy" hooked to an ISHIDA SCALE i want to take a SLC 5/04 and Go DF1 RS232...
1,490
