Issues Connecting to Factory Talk 8.00
Zpiskun
May 2016
Concord
I am having some issue connecting to the Factory Talk Server.
We Have been running an application on FactroyTalk View Studio for about 6 months. it has been running on a Windows Server 2012 R2, 64-bit.
The Server had to have a reboot after a coworker installed a couple php tools.
aprox 12 hours after the server was reset we started losing the connection from our client computers. When the application was started up again the error message states
"The client temporarily cannot connect to the FactoryTalk View SE server in the home area '/' because the server is not available. To Connect the Client automatically when the server is available , leave this message open. to close the FactoryTalk View SE Client window and connect later, click Cancel"
This was a gradual decline starting with one computer not connecting and now its currently at 4 computers.
I am able to ping back and fourth from the server and the now 4 clients (2 running XP and 2 Running Windows 7) that are not connecting to the server, using both the computer names and the IP addresses.
I also tried setting up a new client and i am able to select the application i want to run but when i go to select the area an error message pops up "Unable to connect to the HMI server in area '/'."
Every computer does have and activation for RSlinx and FT view Client. The server also has activation's for RSlinx and FT.
The Firewall on all of the computers running this application and the server are turned off.
It would be greatly appreciated if someone could point me in the direction i should be looking at to solve this issue
Hi
I don´t know if this is the best option... But if you have a complete backup of your system, maybe you can restore and check if everything work´s perfecty.
One thing to check is the Secure Web Site properties is DISABLED in FTV SE.
Click Start > All Programs > Rockwell Software > FactoryTalk View > Tools > FactoryTalk View SE Secure Web Site Setup
Reboot HMI Server
Hello all, hope your week is going well. I am currently working on debugging a Micro850 with Category number 2080-LC50-24QWB. When I connect...
2,365
I'm trying to resurrect an older machine from around 2005 that uses a 140CPU43412A. The goal is to retrieve the existing program so that it can be...
3,450
Hi guys, here's a little description of the issues I'm having. This is not the first time I am using MODBUS to connect with devices, I do it very...
54
15,996
I am trying to connect my 7" Omron NB7W-TW00B HMI to my AB CompactLogix L-31 PLC. Right now I am just trying to pass a single value from my PLC...
3,930
Hi, I am having trouble connecting to a Siemens S7-200 PLC in Citect. - Citect Version: 6.1 SPB, - Driver: SIMPPI 1.00.03.001 - Siemens...
2,690
