J7 problem????
alezi
Dec 2005
Nova Payova
Hello folks,
I’m Aleksandar ,working in aluminum extrusion industry ,today we have a problem with frequency inverter, I need some opinion ,experts opinion , so we are today replacing mechanically variable speed regulator with frequency inverter , before instillation we are check inverter in workshop and setup them. When we connected inverter it is blew out, exactly, block to adapt input, big problem is we don’t know way.
Then we checking all wiring but everything is ok, like: wires, grounding, contacts …,I think maybe fault main switch or over current contactor ,when we to connected circuit on tension input current to pass limits on over current contactor and it to broke supply for inverter, I not sure but I have you, thanks a lot.
If you need any suggestion ask me.
p.s.
Sorry for English
Give us model number for Inverter.
Give us numbers on Motor.
Remove Overcurrent contactor. You don't use an overload with an inverter. The inverter does that job.
Namber is:CIMR-J7AC42P2, , number of motor I don’t have now but it is not wrong because I seed we are check motor and inverter in workshop ,previous post I miss some information like, motor connected in STAR combination and when we put them on machine he have full load, maybe that, but I bolded we are connected inverter with same motor in workshop before installing on machine ,please tell me in which direction you are think .
Best regards
Aleksandar
About motor, motor is 3 phase inductive, star combination, current on unloading is 3.5A,
Motor are connected with angle gear box for movement knurling machine
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
476
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
56
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
217
Hi, I am having a challenge installing a new drive ACS355-03E-44A0-4 as it keeps on displaying Fault code F00018 even when the load is not...
155
I have an issue on my vessel, we have water tight door system created in China, company is no longer operating. We have 7 doors each with their...
169
