just wondering about event tasks
intradave is correct fundamentally about a COS event interrupt, but not quite functionally. From what I can tell the CPLX engine would support a module driven COS event interrupt. The problem is that none of the CPLX modules wil generate a COS interrupt. So, regardless of the cause, the final result is that the CPLX platform cannot perform an I/O COS event interrupt. And, as a result, there is little use for using the event interrupt.
Keith
[OT]
Look at the breadth of products that Siemens and Rockwell have. We only have a very good motion controller that just happens to be able to function like a PLC with limited I/O.
Many manufacturers have plc functionality in their vfd's & motion controllers. Usually there is too little IO (for any useful task I could think for those atleast). Maybe having profinet/ethercat or similar master functionality would open lots of possibilities for doing small machines on just with one programmable unit.
[/OT]
If it is by hand it will work as the speed is low enough, if not you can use some flipflops external like some relais that are set by the switches and reset when seen by the PLC, or electronic ones even faster.
If able to use interupts then is no problem as every interupt will be remembered.
Good Morning , I think I have upper management convinced to begin replacing our SLC 500 PLC's . It is incredible the increase in price on SLC...
2,084
Hey all, I've recently been asked to help spec some SCADAPack controllers for a project. I'm specifically being asked if the E series...
8,086
Hi I just were sitting in my desk and was wondering if by any chance any of you worked for Eaton in Aurora or Berea in Ohio. Aurora was full of...
1,637
Wondering how to "defeat" the left hand most timer in Logixpro I/O simulator Wondering if any one can help answer the attached two questions...
2,226
I'm working with SLC 500 Data File. I have a few numbers like 8.313452e+07 . I forget , how do you convert these numbers . Thanks so much.
2,572
