k8200 3d printer with Marlin Firmware
Mueller34
Jan 2022
Wisconsin
56
I have built my first 3d printer. I used a k8200 kit that was gifted to me and gave it a z-axis upgrade and direct drive extruder. I am in the process of commissioning but have a problem. I have the Marlin firmware loaded onto my arudino mega, and am using repetier to connect. I have all the axis moving the way they need to and homed. The extruder is set. But when i try to heat the bed or extruder independently they do nothing. If i have them both on they heat, but once the extruder is up to temp, the bed has yet to hit the temp and the repetier software is saying i am still giving an output to the bed, but it won't turn on until the extruder heats. Any help? I attached the firmware.
What forum do you think you are in lol?
I have a printer running Marlin on on a mega, I'll compare configs tonight. Are you using RAMPS to control the steppers/extruder/heated bed?
I wired mine up and got it working a few years ago, so I haven't thought about this in a bit.
A derail, until I can look at mine, I had to put a solid state relay between RAMPS and my heated bed, it would burn up the MOSFET's if wired directly to the RAMPS board. Edit: not that this has anything to do with your issue, just throwing it out there.
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
60
I'm a Manufacturing Engineer with limited PLC experience and I am doing some research for our Controls Department. Does anyone have experience...
183
Hello ! I am trying to use an omron cj2m-cpu33 with a CP1W-CIF01 plug in serial connector to talk to a zebra ZT610 printer. I am getting the data...
380
Shot in the dark here, but a customer has this Arca Linerplus Advanced 4.0 printer/applicator for pallet-tagging and we need to change the mode on...
131
Hi All, I currently have an issue to establish connection between my PLC to Zebra Printer. On my side don't have the ASCII card Module to use...
771
