Kinetics 6000-fiber; how to jumper out a drive?
jdbrandt
Oct 2002
Pennsylvania
1,203
{Old Indramat guy here} (*)
How do you 'jumper out', logically, a drive on a Kinetics 6000?
For example, I have a Power Module (Node 20) and three axis modules (Nodes 22, 24, 26), and want to isolate Node 26.
I move the last fiber connector, eliminating the last axis module, but completing the loop.
Logically, I should be (*) able to just disable/inhibit Node 26.
Nothing I tried worked.
What am I doing wrong?
On second thought I think you are correct. You should be able to simply inhibit the axis and be good to go. I also think you would need to leave all the fiber connections as is.
you can go offline to ungroup this axis, then download to controller. If you want to put it back in motion group, you can group it again in offline then download to controller.
I'm fairly new to working with servo control. My training is coming, but I have a customer that needs help right now, so I'm trying to read/work...
2,911
Anyone have a sample program to move a Kinetics single axis servo in Studio 5000? Any help is appreciated.
746
Working on a machine we recieved that has a compact logix plc and kinetics servo and trying to get a better understanding in order to make some...
1,203
Good Afternoon , I need to wrap my head around programming Rockwell Automation Kinetic Servo drives. Would you folks have any training...
1,953
Hi. I have an application where I need 2 servo motors that are mechanically linked to run a gear box (motor A is connected to motor B via 2...
2,331
