Kinetix 300 with RSLogix5000
webs
Mar 2010
Bowling Green
KINETIX 300 with 1769-L30ER
, we are starting up some machines using the above configuration and RSLogix 5000. I'm trying to decipher all the info available. I do not yet physically have these in my hands to power up.
Is the only way to get motion on these through messaging?
Can they use any of the "motion move instructions" for servo motion?
I will need Point-to-Point moves and also some "move to torque" in some cases.
thanks
Have you ever used the old Ultra 3000i indexing drives on DeviceNet ? The functionality is very similar, where an ordinary cyclic I/O connection is used to command functions in the drive.
The Kinetix 350 drives are the ones that use the Logix Motion Axis definitions and Motion commands. To run those, you need one of the CIP Motion capable controllers, like the 1769-L30ERM.
The Kinetix 300 are appropriate for use with the non-CIP-Motion versions of the CompactLogix.
I recently did a Kinetix 300 and MicroLogix 1400 application, and had to do all the Messaging to get data between them.
With the CompactLogix, most of that Messaging will not be necessary because the I/O connection takes care of the important Assembly messaging. You'll still probably need to send messages to alter aspects of the Indexes (like distance or speed or acceleration) but crucial command and status data will be taken care of by the I/O connection.
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
37
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
161
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
249
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
107
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
439
