Kinetix 5500 Clock Jitter
tcotterman
Sep 2014
ohio
Hello everyone, have you guys ever seen this issue?
plc - compactlogix 5069-l310erm rev 31.011
servo - 3 kinetix 2198-H070-ERS rev 7.001
switch - 1783-ems08t/B stratix 6000
automation network on port A2 of plc class C
enterprise network on port A1 of plc class B
As soon as I plug shopfloor into A1 or into the switch I loose the controller being the master clock and it becomes a slave. Eventually over time the clock jitter will fault out the servos.
I have tried the network in star/linear back to linear with the same results. I changed the switch to a stratix 8000 which supports cip sync. I have tried blocking ptp traffic to no avail. Without shopfloor communicating there is no issues with the clock.
Thanks.
Thanks.
Maybe there are other system connected to the shop floor with its clock set as Master as well.
I think you can only have a single Master in the network. Maybe I am wrong
I contacted IT weeks ago they didn't even respond back. Thats when I changed the switch and tried blocking any ptp packets coming in. Its unplugged and they are manually selecting recipes to run instead of scanning barcodes.
Thanks for help guys.
Good day: I am wondering if anyone has experience with the Kinetix 5500 S33 Fault. I have 3 drives in a group set as follows: 2198-H025-ERS2...
30
Hi guys! I have 3 servos for X,Y,Z axis controlled by Kinetix 5500. In Studio 5000 there is one Predefined tag in AXIS_CIP_DRIVE called...
167
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
212
Hi all, Maybe silly question but want to make sure. I have not found anything in the manual about that.. On Kinetix 5500 you can use either 1Ph...
194
