Kinetix 5500 stuck in module startup
Elwin
Jan 2021
Aguascalientes
Hello all, I´m working with a Kinetix 5500 servo drive connected to a CompactLogix PLC... Last week the machine was powered off and disconnected the main supply to apply some mechanical modifications. Now, when we power on the machine, the servo drive doesn't start, it stucks in the loading AB screen (shown in the image). It has not ethernet communication and we cant move through the menu to check the problem.
Do you have an idea what is happening to the servo drive?
Did you have a similar trouble with this servo drive?
Hi guys! I have 3 servos for X,Y,Z axis controlled by Kinetix 5500. In Studio 5000 there is one Predefined tag in AXIS_CIP_DRIVE called...
155
Hi all, New here and new all round to PLC`s. We have a servo drive that runs a cross travel beam backwards and forwards. I am having trouble with...
198
Hi all, Maybe silly question but want to make sure. I have not found anything in the manual about that.. On Kinetix 5500 you can use either 1Ph...
188
Good evening all! I hope you folks are doing alright today, as I've got a situation that I believe I've come up with a solution to but I wanted to...
445
