Kinetix 6500 - Speed is always halved?
alive15
Oct 2015
Montgomery, AL
724
Good morning,
I have a 1756-EN2TR PLC using studio 5000, along with a Kinetix 6500 (2094-EN02D-M01-S0) drive. The PLC commands a certain speed from the drive, but for some reason, it keeps getting halved? This recent issue only popped up today. See picture below, I command a speed of 2.5 inches/sec, but the drive only commands 1.25 inches/sec.
Thanks,
Hi there,
Typically, we only delete threads that are deemed to be spam or otherwise malicious in intent.
Sounds like you found your solution, elsewhere in your code, which is good.
If you have time, and inclination, post any details of your solution on thus thread, so that it may help others who come searching the same issue later.
I question about a kinetix 6500, hooked up to a Allen Bradley Control Logix 5572 controller. The current program uses MAM instruction to bring the...
2,419
Dear team, We are constantly facing M07 incremental loss on one of our kinetix 6500 safe torque. We have changed Servo motor (MPL-B4530K-MJ72AA)...
134
Loving AB right now... We have an Allen-Bradley 2094-EN02D-M01 Kinetix 6500 servo drive that once had safe-speed monitoring which was eliminated...
153
Hello, I encountered a problem with the kinetix 6500 drive, error code s22, loss of 3 phase voltage. After disassembling and replacing the thermal...
186
Hi everybody, I am having an intermittent issue with a Kinetix 6500 drive. The fault i get is a SAFE FLT 05, described as GuardFeedback1Fault in...
905
