Kinetix Control Mode switching
JordanCClark
Mar 2007
Michigan
610
Hi guys!
In the Ultra3000, you could use an input to switch between position and current modes. Is there any similar functionality in Kinetix Integrated Motion?
My application is something along the lines of:
  • Move to a part under test in position mode.
  • Switch to torque mode to simulate a weight
  • Switch back to position mode to get ready for the next part.
I know can 'fake it out' by setting the torque limit down and opening up the position and velocity error tolerances, but it seems kind of hacky.
So is there a better way?
I know that in the case of CIP motion, this can be done programmatically by using an SSV instruction. In the application where I use this, there are a few axes that I frequently change between position and velocity control. The logic executes an MSF instruction, then writes the SSV, then executes an MSO instruction. Write 1 for position, 2 for velocity, 4 for torque (current).
Class Name: Axis
Instance Name: <Axis Tag>
Attribute: ControlMode
Source: <Value to write>
Thanks for the info. Unfortunately for me, I couldn't find it. Then I found out it was SERCOS. Which makes that attribute unavailable.
I did, however, find one called "Servo Loop Configuration", that I believe should do the trick.
If anyone else has experience with that attribute in a SERCOS environment, feel free to jump in. The water's still nice!;)
Hello, Searched the forum and found this old post in regards to dynamically setting the control mode of a Kinetix CIP AXIS drive in the PLC...
1,121
Dear colleagues, hope you can help on that matter. We have a project where we need to control 3 servomotors to move a auger feeder system...
38
1,178
Possible for two processors in same rack to have separate motion groups across a single Kinetix Rack using a single EN3TR? One 6500/5700 rack, 8...
426
Hello, I have an application where 80% of the time, an operator will be needing to issue very accurate MAM or MAJ instructions to a Kinetix 5500...
709
Hello guys, Our existing kinetix control module revision is 3.001 but now I want to replace the faulty controller by new revision 3.003.i fixed...
3,816
