L43
thailapillai
May 2016
HI,
I'm trying to connect a powerflex d525 rive to L43 Compact logix processer.
its showing the device in rs linx once IP assigned.
But still its not communication with processer thru Ethernet once program downloaded(we assigned same ip)
is there any other setting in configuration.? Please help
can you open the drive on in logix? on the communications tab what is the error message?
The configured IP address in program and pf525 IP address is same. I don't know why it's not connecting .
But pf525 showing in rslinx
Take a screenshot of the connection status window as illustrated above.
If all you post is "I set it up but it doesn't work", nobody can do anything but guess about what you set up incorrectly.
Apparently, they are not compatible and i was hoping there was a work around.
696
I have run into several systems the last while that are using L43 CompactLogix processors to control 6000 series servo drives over a Sercos loop...
1,030
Hello All I have a machine built in 2013 but never commissioned. I have it almost complete. It has 2 Kinetix 6000's with a CompactLogix L43 with...
1,210
Trying to configure the 2nd drive on this machine. It is being difficult. I have the gains speed encoder data all with good data. when I try to...
1,862
Good day all. I'm trying to create a new project with a 1668-L43 CompactLogix controller. When I try to create new, That controller is not in the...
1,906
