L5K file from RS5000 to GP Pro EX
sjanes9
Nov 2012
Lexington
52
I am using an Compactlogix L23E PLC Revision 20. And a Proface IPC Series PS-3651A HMI. I am working with GP Pro EX V4. I am communicating from the PLC to the HMI Via Ehternet IP.
I created a new program in GP Pro and when I imported my L5K file that I exported from the PLC and I look at the System area start address in the GP Pro EX program. It reads [PLC1]Local:1:I.Data. If I try to click on the Enable system Data area check box. I get an error that reads, address out of range Check the address and selected items. Also, none of the data that I have in the PLC is enabled on the HMI. Any help would be greatly appreciated
I think you will have to Alias your physical I/O to use with Proface. You could also just map the I/O to Bool Tags.
Import your tags to a csv file from rs 5000. In GP pro go to device/plc. Enter in your PLC IP address. Select compact logic. The one that says native I believe. I don't have the software in front of me right now. Import your csv file. Then all your tags will be there. Let me know if you have anymore questions. I just did this twice today. Bullzi is right make a seperate routine for all your I/O. I call mine alias tag configuration. Then just import your tag names. It is also easy to switch them around later if you need to.
I think that makes sense. I am not actually using any of the I/O in my program. I am using BOOL tags already. Do I need to map those to other tags? For instance, I have a drive enable button tag? Do I need to map it to another BOOL tag? Also, I have an output tag that is used to show the drive has been enabled. Map it to another tag as well? Again, I am not using any of the actual I/O in my program.
Make sure all of your tags are in the controller scope and not under a sub routine. This error will happen if not.
Hello Could one of our AB users please create a simple L5K file for me? A few basic tags, a few structures and a few tags of the structure type...
195
We updated from Crimson 3.2.0067.0 to Crimson 3.2.0071.0 and now there is no comms between the 12" Graphite HMI and the AB Compact Logix PLC...
517
Hello Everyone! Hope you guys are doing well during this pandemic. I am trying to auto generate L5K file for Studio5000. The AOI is in encoded...
1,715
How can you ensure that a Synchronous File Copy instruction has completed before you execute another Synchronous File Copy instruction on the...
1,627
Forgot my dongle at work, would someone please save as a l5k file for me. Have to do some importing of tags for rsview 32. Thanks.
1,480
