language convertor in fanuc o-m
I don't have a 0M in front of me but try this:
Go to MDI mode
press SETTINGS soft switch on the monitor
scrolling down you should see language selections
Try posting at www/practicalmachinist.com
Sorry I wasn't of more help,
Rod
I don't know if the zero uses the same parameter numbering scheme, but I have a manual for a Fanuc PowerMate H, and for it, the value in parameter 3102 determines the display language.
0 = English
1 = Japanese
2 = German
4 = French
16 = Italian
32 = Spanish
The display may show bits rather than a numeric value. It might also show abbreviations for the language associated with each bit. The manual gives:
Bit 0 - JPN
Bit 1 - OGRM
Bit 2 - OFRN
Bit 4 - OITA
Bit 6 - OSPN
You could look at the parameter values, and if you find the the current value for 3102 is 2 (Bit 1 set), try changing it to zero and see what happens.
According to the manual you need to cycle power following a change in the value. Of course, you will need to set the PWE bit before you can make the change.
Hope this helps
Developed a FactoryTalk SE program in English (Canada), finally setup the alarms and the message is reading "Message not defined for language...
49
Hello Friends I have 2 languages in my app, en-US, es-MX. I need to send CurrentLanguage to PLC, I am trying with Macro in Global Connections...
189
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
648
Hello, I was wondering if anyone could let me know how to change the audit trail messages language on Factory Talk ME. I am currently working...
471
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
470
