Latching position and counting rotation numbers
mark.plc
Nov 2017
Hello everyone!
I don't know how to program some thing.
I will tell you an example.
I have a rotary table, which is rotating from 0 to 2048 impulses (high speed counter counts impulses). I need in some situations latch the position (rewrite actual position to the register) and count number of rotation from this latched position.
It must be a real type number with one decimal place (e.g. 1,5 rotation, 2,8 rotation).
With an integer i don't have any problem but i don't know how to bite this with a decimal number.
Mitsubishi FX5, GXWorks 3
Thanks for help! :)
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
202
I am curious why my latches do not work and maybe someone here has some insight. I have created two AOIs. One AOI latches an output on (ON)...
1,804
I'd like to get some feedback on the use of latching/unlatching relays. (Something I've never used in my limited programming experience.) I've...
4,857
I figured out a solution to a vfd issue... at least in theory. Yaskawa has a program called Drive Works EZ that you can have PLC-type functions...
3,867
How get steady latched from HMI push button without doing any program in PLC for latching and after pressing second it is unlatched in connected...
1,658
