Laurent said:
A carefully selected stepping motor still remains a pretty good choice in lots of projects. I have been in the field for years and the number of applications always seems to be endless whatever you think about.
I strongly agree! The idea of a compact, variable-speed, rotary actuating device, that moves in discrete, digitally controllable steps is hard for a machine designer to pass up. We need to be aware of the limitations, however, and design accordingly.
The load inertia plus your drive mechanism should deserve a quite strong motor. Did you experience the required starting torque?
This is probably my main concern at the moment. I'm holding back on selecting a specific motor, for now, as I plan on spending some more time at my customer's plant, running the existing machine, and getting a better "feel" for how the material acts and handles. My customer has also ordered one of the 500 lb. rolls of wire, so I can get more precise dimensions and calculate the inertia more accurately. I also plan to check the pulling tension on the existing operation with the 100 lb roll, perhaps to make a preliminary calculation for the 500 lb roll, as the inertia should be directly proportional to weight (given that the radial dimensions are at least similar.)
If you plan to keep working in NEMA34, ask PacSci for quotations among their Sigmax K3x series (select 8 leads / K types). As a matter of fact, extended prices should reflect some hugely extended capabilities. But this will allow you to get high torques while dealing with mid-range voltages (less than 90V)/currents and a low-cost homemade power supply (compared to bigger motors often requiring up to 130/160VDC). Open frame OEM drives up to 12Amps or metal housing types up to 12/14 Amps may be easily found.
Thanks for the info! I've been checking out their website, and it's comforting to hear from someone that has experience using their products. Right now, my gut tells me that my torque requirement will put me somewhwre near the top end of the NEMA 34 category and the bottom end of the NEMA 42. I will be getting harder data on this in the near future.
As far as no micro-stepping modes are involved, any PLC with a dedicated pulse function (solid state output is mandatory!) including manageable accel/decel will suit this project with peripheral I/Os rather than an indexer.
From my limited understanding of the subject, it seems that micro-stepping does not really improve resolution, as the rotor is trying to stop at an "unnatural" position. I would not plan on using micro-stepping for any purpose other than to smooth the rotor movement. Are you saying that I would not need to purchase one of those hi-speed counting modules, like the HO-CTRIO, for this application?
pstephens
