lenze smd vfd
tny
Jun 2005
usa
105
hi all, i am building a new conveyor system and i have to use lenze smd vfds. i am not much familiar to them, and i have no time for reading big pdfs :)
i just want to start it via an input with fixed setpoint freq and adjust the ramp up ramp down times. wich parameters do i have to use and how should i make the connections?
thanks
Relay Across terminals 7 and 28
You can have set speed or speed pot.
Set codes 10 to 11 .
The PDF manual is really easy .
Its a breeze !!.
Rtfm
No time for reading = no time to do the job properly.
Even if you learn what terminals to connect too you still have to read to learn how to do setup/parameterization for the drive, the procedure involved varies from drive to drive and brand to brand.
i can not remember how many pages of techincal document since i learned to read :)
but now, i didn't sleep since yesterday and i am gonna fall down 10 minutes later i think, so i didn't want to read any thing.
and i want to add that,after my firs msg i read the documents,and solved the problem:)
Hi folk, I would like to know what kind of Parameters should I setup for controlling with Profibus. My old Lenze 8200 motec 0.25kW have a busted...
87
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
239
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
185
Hello guys, I'm trying to use the Lenze GDC 4-14 with the system bus adapter 2177, but it doesn't appear in the communication window. It's like I...
232
Hi everyone. I got the endless "booting/connection" sequence on my Lenze 9400 HighLine. EZAEBK1001 Keypad is showing "question mark" while trying...
293
