Level Sensor outputs
CAAJ
Dec 2014
Fairhaven, Ma
47
Hello All,
Does anyone know if a 4-20ma signal would provide enough resolution for a level sensor. I want to make sure that the level recorded by our compactlogix controller is accurate.
We would like to utilize an ultrasonic level sensor.
Any feedback would be useful!
(y)
Not sure what, where, and how much you are measuring.
I use radar units with 4-20 measuring dry product and they work great.
Sorry about that. We're looking to measure high and low viscosity fluids in a rectangular storage tank. The unit is only 4.5' tall. And I would say we would like to shoot for about <2% accuracy.
Typical A-D cards
use 12 bit resolution. That's 4096 counts, much better than 2%.
If you ensure that your sensor range is reasonably close to the range of your tank levels, you will get sufficient resolution.
e.g. If you are looking to measure a 5' range, shop for a sensor with 6'-10' range, so your 4-20mA output will be maximized over your range.
how to program a laser level sensor to a cooler tank with an AB plc
1,329
Hey guys, We have a metal container at work, we fill with saw dust (20fts x 15fts x 10fts) with the top open but we normally put a container...
1,557
Hi everyone; Im having some problems with a digital level capacitive sensor. I wired it in the NO configuration and the input of the digital...
3,424
Hello everyone, I need to install a level sensor in an existing plastic tank. It will go on top and there will not be pressure on it except if...
7,368
Hello, I'm looking for a float style temp/level analog transmitter (0-10V analog) for a water tank. There are no chemicals in the water but the...
1,680
