Light Curtain Muting Instruction Help
Aug 2015
Detroit, MI
177
Ok all, I'd appreciate any and all help understanding this -
Lately I have been having some trouble with a discharge light curtain on one of our palletizers. I *suspect* it may be due to a reflective style photoeye reflecting off of a film-wrapped product or a very glossy package. The light curtain in question gives an input to a 1769-ERMS Compact Guardlogix controller, utilized by an FSBM instruction. I have tried using a MOV instruction to grab the fault code and copy it to another tag after it happens (Operators around here like to clear things quickly, go figure) so I can look up what it means but the code I am getting is nowhere to be found in the instruction help. First time I was able to get '37376', and just a minute ago I got '37396'. What the heck does it mean? Do I have a lack of an underlying understanding of the operation/instruction?
Ok I think I figured it out on my own...
For all who may be interested, or want to correct me (feel free)...
The values I was getting were in a decimal format. The fault codes in the instruction help are followed by an 'H', which I believe stands for Hex. Converting my decimal value of '37396' to a Hexadecimal value gives me a value of '9214'. Slap an 'H' on the end of that and we have ourselves a legit fault code in the help section.
Math.....:angr:
P.S. That fault is all 4 PE's are clear but the curtain is still blocked.... new theory: PE's too low/Seeing through pallet.
Yep, that'll do it every time. Most fault codes are in hex, no idea why. Probably a hangover from early computing days when hex was all the rage.
Most muting sensors I see are emitter-receiver type, to prevent false reflections like you initially suspected. If they're seeing under the pallet, well, can't help you there - but an emitter/receiver will certainly help if all four sensors think they're clear because they're reflecting off the wrapping. If you think about it, that's how the PLC knows there's a fault - because the reflective sensors (PE's) think they're clear, but the emitter/receiver sensor (light curtain) insists that it isn't.
Scenario is robotic cell that stacks pallets onto conveyors. Conveyors move stacks of pallets out of cell to pickup location. Cell is fenced...
1,870
We have a request to mute a light curtain when the machine is in it's home position. So that air is not dumped from the lines while the operator...
3,864
We have a muting light curtain setup like the picture I am attaching here. However, a pallet sometimes hits the photo eyes (MS1 & MS2 in the...
26
9,000
This will be a bit long-winded, but it was a good learning experience and may be helpful to someone else... To guard the exit of an automatic...
3,714
Hi We have a little problem. We have a conveyor going in to robot cell, but rolleys transported by conveyor are so little on material and what is...
3,381
