Light curtain muting
TurpoUrpo
May 2008
Switzerland
1,571
Hi
We have a little problem. We have a conveyor going in to robot cell, but rolleys transported by conveyor are so little on material and what is even worse, there is lot of different types so one bar might be enough in different position that we have not been able to get reliable light curtain muting using photo cells.
So I tried to find references on is it possible to use any sensor, eg. inductive to mute without affecting safety category of light curtain? And if, what is possible reference to look at?
All examples and references are done with photo cells and no where could I find anything about permissible sensor types. I believe it would be enough if one can guide me to right IEC or similar standard used in EU.
Thanks.
In our experience we couldn't find the correct sensor either.
The general safety rule that we adhere to is to wire up our muting sensors to a sick flexisoft safety PLC.
The supply is 24VDC but here is the safety side it sends a pulse on this supply every 200ms. This is suffice to say that the sensor is monitored and cannot be bridged to supply.
Sensors we have used to date are mainly reflective monitored BUT as you mention I don't see why you can't use other types as long as there are 2.
Muting lamps are a must.
I will watch this thread for updates too.
Scenario is robotic cell that stacks pallets onto conveyors. Conveyors move stacks of pallets out of cell to pickup location. Cell is fenced...
1,870
We have a request to mute a light curtain when the machine is in it's home position. So that air is not dumped from the lines while the operator...
3,864
Ok all, I'd appreciate any and all help understanding this - Lately I have been having some trouble with a discharge light curtain on one of our...
2,509
We have a muting light curtain setup like the picture I am attaching here. However, a pallet sometimes hits the photo eyes (MS1 & MS2 in the...
26
9,000
This will be a bit long-winded, but it was a good learning experience and may be helpful to someone else... To guard the exit of an automatic...
3,714
