Linux library to read/write to SLC/Micrologix controllers
suBrett
Aug 2009
Union
I've done a bit of searching here and on the net in general and most of the information I find seems a bit dated and stale.
Does anyone know of a decent library that runs under Linux (perl/C/C++) that allows reads/writes using DF1 via PCCC/EIP to the SLC/Micrologix platforms ?
Thanks in advance for any pointers.
Hello, I am assigned to develop a C++ application which will utilise EtherCAT library to communicate with EK1100 unit with digital and analogue...
3,686
Trying to write a bash script for BusyBox and I can't get the FTP command to accept the Username and Password. I have tried using FTP...
1,160
Hello all, I have a client that needs to externally control some valves at a small plant, nothing fancy. (for which I just need digital IO)...
3,932
I have a linux server (on prosumer hardware), debian stretch 10. There was some utility works in my area and they hit the power line. The server...
3,202
Hi there PLC aficionados, I have a quick question for you. Do you use Linux in your integrator/automation engineer/Technician role? If, yes which...
20
8,336
