OT: Linux guru's
the_msp
May 2008
Northern Ireland
1,271
I have a linux server (on prosumer hardware), debian stretch 10.
There was some utility works in my area and they hit the power line. The server is on a UPS but it drained as I was away.
Ever since, the server only boots for a while then shuts itself down. About 17 minutes after booting.
I pulled the log from dmesg, attached, can anyone spot anything that points to a specific piece of hardware before I start randomly replacing components?
I've tried it on mains only, the UPS isn't the issue. All the other hardware in the same server rack is fine.
it may not be shutting down, it's looks like it's going into suspend mode. See the entry at around ~1244s, 994s (there's the 17 minutes) after the last boot-ish entry at ~250s.
It does seem to wake again though. It sounds like it is not normally connected (comms, not power) to the UPS, so it can do a clean shutdown when UPS loses the mains.
What are the power settings? One thing that would trigger this would be the lid of a laptop closing, but this does not sound like a laptop.
This entry
[ 2464.311619] Suspending console(s) (use no_console_suspend to debug)
suggests there might be a way to get more diagnostics.
I am not a Linux guru. It seems odd that it stays running for a time period then shuts down. Is that time repeatable? If it is repeatable, is it possible it is looking for a good signal from the UPS? Are there any tasks designed to run on time if a certain input is seen (or not seen)? I am obviously just guessing. The fact that it runs for a while then shuts down after that much time is intriguing.
Hi doctors Brian and Forsythe,
yes Brian you are correct. I checked the syslog and saw this:
Feb 11 16:49:46 octo gnome-shell[1035]: Screen lock is locked down, not locking
Feb 11 16:49:46 octo systemd[1]: Reached target Sleep.
Feb 11 16:49:46 octo systemd[1]: Starting Suspend...
Feb 11 16:49:46 octo systemd-sleep[3551]: Suspending system...
Feb 11 16:49:46 octo kernel: [ 3670.491866] PM: suspend entry (deep)
Feb 11 16:49:46 octo kernel: [ 3670.491868] PM: Syncing filesystems ... done.
I google-foo'd and ran this:
matrix@octo:~$ sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
Created symlink /etc/systemd/system/sleep.target → /dev/null.
Created symlink /etc/systemd/system/suspend.target → /dev/null.
Created symlink /etc/systemd/system/hibernate.target → /dev/null.
Created symlink /etc/systemd/system/hybrid-sleep.target → /dev/null.
Then went to the server (it has Gnome too) and checked the GUI, the only thing in Power settings is display off time which is set to never.
Odd that it put in a shutdown timer after a power cut by itself...
There is no link from the UPS to initiate a shutdown, just the C13/C14 cable.
Maybe a power supply issue? how hard would it be to replace the PS?
I have always built computers myself, for probably 20 years. Not just for me, but for friends and family. Computers shutting down without being told has almost always been, if not always, the power supply.
Could be that after about 17 minutes, it is sufficiently warm and bites the dust.
I am using PuTTy to SSH in, after it boots. I ran a ping with timestamp in PowerShell on my Win 10 desktop to determine the ~17 minutes.
So, it is shutting down, SSH tunnel disconnects.
I have also been building computers since 2003, just not as au fait with Linux as I am with Windoze.
I'll do the PSU soon.
Trying to write a bash script for BusyBox and I can't get the FTP command to accept the Username and Password. I have tried using FTP...
1,157
Hello all, I have a client that needs to externally control some valves at a small plant, nothing fancy. (for which I just need digital IO)...
3,929
Hi there PLC aficionados, I have a quick question for you. Do you use Linux in your integrator/automation engineer/Technician role? If, yes which...
20
8,333
Long time reader here but don't post much as I usually find the answers I need in the forum search. I am trying to create a dynamic selection...
2,286
I can already tell this is taboo; but I am genuinely curious if anybody has attempted this via WINE or any other emulation software yet? I am a...
3,050
