Load driving capability
Charbel
Jan 2012
Beirut
307
Dear,
i want to understand something...
i hae a specification here that says that pressure transmitter loop powered, 4 to 20mA HART output, load driving capability of 600 ohm at 24 VDC.
what is the load driving capability?
That is more often referred to as max load, or max resistance, or max burden. It simply means that with the 24 VDC power supplied the transmitter will enable it to send a 4-20 mA signal through a circuit with a total resistance of 600 Ohms. That allows, for example, putting a chart recorder with 250 Ohms resistance and a PLC with 250 Ohms resistance on the input channel in the loop and the transmitter will be able to drive the signal through the loop.
If you exceed the max load for the transmitter your output signal will typically drop to zero mA.
Sensor Imipedance and effect on Input module
Dear Tom,
thank you! i was looking at the endress&hausser Promag 53 datasheet, please check below:
[FONT=E+HWeidemannCom-BookBd][FONT=E+HWeidemannCom-BookBd]
"Promag 53​
[/FONT]
[/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]
Current output:
active/passive selectable, galvanically isolated, time constant selectable (0.01...100 s),
full scale value selectable, temperature coefficient: typically 0.005% o.r./°C (o.r. = of reading),
resolution: 0.5​
[/FONT]​
[/FONT]μ[FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]A
• active: 0/4…20 mA, R
[/FONT]
[/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]L [/FONT][/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]< 700 [/FONT][/FONT]Ω [FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book](HART: R[/FONT][/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]L [/FONT][/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]250 [/FONT][/FONT]Ω[FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book])
• passive: 4…20 mA, operating voltage V
[/FONT]
[/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]S [/FONT][/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]18...30 V DC, R[/FONT][/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]i [/FONT][/FONT][FONT=E+HWeidemannCom-Book][FONT=E+HWeidemannCom-Book]150 [/FONT][/FONT]Ω"
I assume active is field powered and passive loop powered.
What is Ri? RL is the load resistance as you explained before.
and why RL for HART should be larger than 250 ohm?
what are the restriction on the input module resistance?
thanks!
Charbel
Hart requires a resistance > 250 Ohm in order to have enough voltage to make the communicaitons signal readable by Hart devices. Remember, Hart is a high frequency communications signal superimposed on top of the 4-20 mA.
I am not sure about the Ri. I could speculate, but i suggest you contact your source for E & H or their tech support.
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
46
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
85
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
256
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
115
