logic 5000 messaging help needed (DH+ bridge)
Russ
Jun 2002
Ohio.. Go Bucks!!!!
261
We're upgrading a plc5 to control logix and are using a dhrio card to communicate with the DH+ network... but I can't figure out the bridging.
The plc 5 message instruction looked like this:
Data table address: N15:15
Local node (octal): 75
Local remote: remote
Remote link: type: remote
Remote station address: 40
Remote bridge: 2
What do I do? The dhrio is in slot 1.
DH+ bridging can be tricky, but the DHRIO does support it. You just have to be sure that all of the Link IDs for all the devices are set correctly.
Go into the old PLC-5 program and determine what the Link ID value was for the DH+ channel used by the MSG instruction.
That's the Link ID you'll have to assign to the 1756-DHRIO's DH+ channel using the DHRIO configuration applet in RSLinx Classic.
Thanks. I matched link ids, then set up a dh+ bridge with 2 links. I can see the target plc (node 40).
But no luck so far.
My path was set up like this:
1,1,2 (channel A due to 230k), 8#75,1,1,3 (channel b), 8#40
The bridge is at 75. Slot 1 channel b contains the network with my target plc (node 40).
My source link is 6 and the destination link is 2.
I have pics of everything, if anyone's curious. I even have ibuprofen lol
Good day everyone. if you have a logic for 3 pumps (lead/lag/off), would you please email it to me? I really appreciate it!
220
Uploaded this project from a PLC that we need to make changes to. I am trying to figure out the reason I am unable to open the actual logic. Do I...
2,242
Is there any way to install multiple versions of studio 5000 Logic Designer or do I have to install them all individually? Also, I am assuming...
2,413
Hello, I need help making a logic modification to a RS Logix 5000 program. I can email the program and give plenty of insight to it plus I have...
2,208
Hi. I have been dealing with this for years. Does anyone know why or, how my AOIs are not allowing me to look in on its running logic while I am...
7,649
