Logix 5 K File Extensions
The Plc Kid
Feb 2009
Macon, Georgia
3,233
What are the .SEM and .WRK file extensions for? I see them along with saved project files sometimes. Why are they created on some project saves and not others?
Not exactly sure about the extensions but they are ""live" files.
They open up automatically when you work with RSL5K and disappear when you close the actual RSL5K software.
I have some as well but because the PC had to be rebooted and the RSL5K was never closed prior to the reboot.
Probably a scratch pad of sorts.
It was always my understanding, (and I may be wrong), that these files were there to prevent two users opening the same project from the same source.
I have never seen them any size other than 0 length, so am dubious as to their use as "swap" files, but then i've never monitored them while "working" with RSLogix5000.
Anyway, if RSLogix5000 is not running, and there is no possibility of another (networked) PC having the file open, then it is safe to delete them. They will get left behind if RSLogix5000 is terminated abnormally, or power is pulled on the PC. The next normal closure of a project will delete them anyway, so it's probably not even worth worrying about them.
I am trying to import addresses and symbols from a PanelBuilder32 application into the RSLogix 5 Address/Symbol database - however each time I...
552
I stumbled onto this behavior the other day, then went looking for old forum posts with the assumption that "there is nothing new under the...
784
On my laptop I have an old.acd file with important comments in it. The file was modified and downloaded to my AB-1756 long time ago. Later a few...
1,999
Hello All, I am working on converting a program written in RSLogix 500 to Connected Components Workbench. The MicroLogix to Micro800 converter...
1,209
PLC is ControlLogix 1756-L73 CPU with firmware 28 In the PLC the value for A60[110] is "AT", Style ASCII, Data Type INT. In KEPServerEX I tried...
1,567
