Logix 5000 Generic Ethernet Module Setup
TheRooster
Jan 2022
USA
39
Hello all,
I need to add a module in logix for an SMC pneumatic valve manifold specifically EX600-SEN3/4. The eds files I add crash the program when I try and create a module, so unless anyone can help with that I am just going to create a generic ethernet module. Anyone know where I can find the following info:
Comm format
connection parameters
Input instance and size
Output
Configuration
I've looked on the manuals I can find and am struggling to find the info. Can post screenshots of whatever if needed.
Thanks for your help!
If you mean to put in the IP address of the EX600 into web browser, then yes.
After logging in with default password (in manual) the first page shows what is physically attached to the EX600 and also what the Input and Output size is.
You can also monitor and force outputs
Thank you all for the replies! I was able to log in via web server and the info lined up with the pic Joseph posted. I was able to at least get connected and now hopefully I can get my I/O squared away.
Cheers!
I used one at my last place with several input modules and setup was pretty straightforward. It's been running great for about 9 years with zero issues, so I decided to use them again here. The only issue we've had here is a damaged sensor cable killed an input module.
​Hello everyone, I triyng to link a Power Module eMB-60R from Robot Adept Viper s650 to CompactLogix, version 19.11 I followed exactly the...
2,655
Hello: I have not been able to get RSLogix 5000 to display expected configuration screen for 1732E configurable armour blocks. Waiting for RA...
39
12,417
Does anyone know the comm format, Assembly Instance and Input/Output size for a Rinstrum C500. It appears their EDS file does not work for RSlogix...
1,611
Hello, I’m communicating a ControlLogix 5000 with a Yaskawa A1000 drive, via a Ethernet 1756en2tr module. I installed the drive interface as a...
3,090
I am trying to add a generic Ethernet module to RSLogix and keep getting an invalid size error. There are no inputs, only outputs. I am using...
5,609
