Logix5000 - Tag inside a tag
imonline
Mar 2006
New Brunswick
I've written a ladder program, on PLC5 that inserts a tag within a tag. I've tried this in logix5000 and I keep getting an error. How should I write this in Lx5000?
Here's the PLC5 code:
ADD Source A T4:15.ACC Source B N300:[N300:0] Dest N300:[N300:0]
Hi all, I've been using Logix5000 for a while, first version 24 and recently version 32 as I had to update for working on the newer CPU modules...
2,268
I'm currently working on an MES interface PLC which passes around a whole bunch of strings. A lot of these strings are really just to allow for an...
1,127
I am having a problem understanding how to assign tags for a simple stop - start push buttons. The Logix 5000 routine to stop and start the pump...
17
4,950
Hello, I am tasked to update a CompactLogix PLC program on a live system. The updates I need to make involve changing a user-defined data...
2,110
Hey guys, I need to have a boolean in Logix5000 that's always on. In other PLCs I've programmed (like GE, for example) there is a system tag...
28
6,714
