Logix5000 tag monitor update
jimpad
Sep 2004
Paducah, KY
88
When I monitor tags in the "controller tags", "monitor tags" folder I have a bunch of question marks and my data does not update. When I monitor a tag value in the "quick watch" it does update. When I edit a tag value in the "monitor tags" folder it does update, when I edit the same tag in the "quick watch" it doesn't update in the "monitor tags" yet it does in the ladder and in the "quick watch".
What gives?
Do I somehow have to enable auto refresh of the "monitor tags"?
Thanks,
Jim
I'm guessing here, but this sounds like a comms or PC resource issue. I've seen tags sometimes take a little while to update, espcially on a heavily loaded comms link, and I can only think that the odd behaviour you are seeing is similar?
Has it always done this? What has changed?
I've only just started the program so I can't say if something has changed. I really don't think I have much traffic and I'm using the enet connection. The thing that puzzles me is the immediate update if I'm using quickwatch.
The general comment I received from a Rockwell service technician is that it is for "quick and dirty" monitoring of a value and not to rely on any type of consistent performance. If you want to monitor reliablly within RSLogix 5000 use the trending.
I have also seen this issue running 13.0.2 & 13.0.3
Darren
Hi, I am looking for a user manual or instructions on how to setup the Tag Data Monitor tool on RSLogix5000
2,154
I'm currently working on an MES interface PLC which passes around a whole bunch of strings. A lot of these strings are really just to allow for an...
1,120
I am having a problem understanding how to assign tags for a simple stop - start push buttons. The Logix 5000 routine to stop and start the pump...
17
4,940
Hi all, I've been using Logix5000 for a while, first version 24 and recently version 32 as I had to update for working on the newer CPU modules...
2,266
Hello, I am tasked to update a CompactLogix PLC program on a live system. The updates I need to make involve changing a user-defined data...
2,103
