LogixPro batch simulator
Rouxgaroux
Nov 2019
LA
Hi, I’m new to the forum and very new to PLCs. I’m working on a project in LogicxPro and have an issue. Any help would be appreciated.
What I want my program to do is have the idle light on when it’s in RUN mode. Once I press start I want pump 1 and 2 to fill. Pump 1 fills to 150 and pump to fills to 50. Once the pumps are done I want the full light on and the mixer and heater to turn off. Once the thermostat reaches the specified number I want both the heater and mixer to turn off, the full light off, and pump 3 to empty the tank. Then the idle light turns back on.
Ideally, I’d like to restart the process by pressing start again.
Right now it works until pump 3 empties the tank. Once it’s empty the heater turns back on and the full light is still on.
The images won't open for me, and, is there more of the program? Zip and attach
the .rsl file. If you can, print it to a .pdf file.
I am working on the batch simulator in the logix pro software.
1,911
Can some one please help me I have done Logixpro simulator's Batch mixing Exercise 3 got everything to work except when you are running the...
6,095
I cant figure out hpw to get the tank to stop filling at 90%. help please:banghead:
6,087
Hey everybody, I am having trouble with the Advanced Batch Mixing Excersise - Excersise #1 on Logixpro. One of the requirements is to be able to...
12,188
Sup, I'm working on a simulation on Logixpro, the Batch Simulator. So far I have exercise 2, some what done. (code provided on the bottom) Problem...
64
93,136
