LogixPro To Convert Temperature
megaherz
Dec 2009
Some Place
Does anyone know how to make this work?
I've tried with the math functions but my "DIV" component isn't operating the way I want it to.
Need more information. Perhaps you could post an example copy of your program code or a pdf printout of the logic in question. More information would enable us to help you.
using these formulae, i have to make my plc program convert temperature
C = 5/9 (F-32)
F = 9/5 (C+32)
my instructor suggested i use a Timer as a temperature base, but i went with the counter since the timer moves too fast, this is what i have so far (yes i am aware that the DIV is not addressed correctly)
Does logixPro software support floating point numbers?
If so delete the "DIV" instrction and replace source B in the "MUL" instruction with .555 ( 5/9) a constant.
Integer registers eg. N7:2 does not give you decimal values.
SELECTED NEW FILE SELECTED PROCESSOR TYPE SELECTED I/O CONFIGURATIONS IM UNABLE TO CONFIGURE MY I/O’S. I HAVE A PAPER COPY OF A PROGRAM AND I...
97
Good morning, I am currently working on the LogixPro Advanced Batch #2 Multiple Mode of Operation and got stuck very close to completion. Link...
2,259
Hi folks, i'm pretty much new on this topic and i need some help with the dual compressor part 3 and 4, currently working on part 3 i cant make...
20
5,194
Hi, I'm using LogixPro Simulator, and I'm experimenting with BSL. I know how BSL works, but what I am trying to do is access the value of an...
1,414
Hello Gurus, I am working on the elevator exercise of LogixPro and my output on the subroutine is being energized without its flag being called...
2,225
