LOGO! 8 TIA portal WinCC
domyplc
Jun 2019
UP
Hi all experts,
I am LOGO! 8 PLC programmer, and now I am beginning to start SCADA developement. I want to ask which software should I install ?,
1. TIA portal with Siemens SIMATIC STEP 7 Professional & WinCC Professional 15.1 x64
2. WinCC RT Professional 15.1 x64
3. STEP 7 Professional 14.0
4. SINAMICS Startdrive 14.0
5. WinCC RT Advanced v15
Please excuse me if my question is not OK as I am beginning scada developement I know nothing about it and I can get limited software through my college programme.
I am confused too because I found that "Up from version 12 of WinCC the driver “LOGO” is available" and also "I think the Logo! communication driver is only available for a WinCC RT advanced , not professional." in this post : unable-to-connect-tia-15-version-to-logo-8/185145
Please hep me so that I can learn SCADA developement with my LOGO8
Waiting for your fruitful reply,
Thanks and Regards
Hello domyplc,
Welcome to the forum.
What are you wanting to program? Is it an HMI screen, or a PC application?
You have frequency drives in your application?
If it is just for practice, I don't think you will need a runtime license.
"SCADA" and "LOGO!" in the same sentence is a bit out of proportions IMO.
A LOGO! is supposed to do some small simple task.
If you need a user-interaction you can use either the integrated display, or the integrated webserver.
I second that
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
359
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
297
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,082
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
987
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,048
