Logo Comofort 7
Brian C
Jun 2011
Vancouver
Does anyone know how to make a on to off contact in Logo Comfort?
"on to off" contact is available in Koyo but not in Logo.
I try to do a off delay of a float switch from on to off.
Greatly appreciate for the help!:nodi:
not 100% sure what the problem is.
Is the KOYO, you refer to, a PLC or a smart relay like the logo?
Thanks for the reply Ian. Sorry to confuse you. What I meant for Koyo is Automation Direct 5.
What I mean is the c110 (the contact point by the red arrow) in the attached image file. It is a on to off contact or negative differential contact. But this contact is not available in logo soft. Know any tricks to do that in Logo?
Hello Brian C,
This example is identical to its logical operation.
Note that you must use gates "AND" to detect positive or negative edge.
Best regards,
Daniel
One Shot Made from Common PLC Instructions
A common name for this type of contact that only is true during a transition from off-to-on or on-to-off is an "edge detector" or "one-shot" contact. If you search for "one-shot" you can find many examples of how to create a one-shot using common PLC instructions. Here is one method. Relay bit "One-Shot 7B" goes on or true for only 1 scan for each time that the Pushbutton Trigger is pressed.
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
377
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
308
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,087
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
1,003
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,057
