LOGO - edge detection
tweazer
Mar 2009
Vancouver
Greetings, Programming a Logo with Comfortsoft V7 I see no DF instruction for differential or edge detection.
I have resorted to using AND and NAND function blocks that have + and - edge detection respectively. AM I missing something? :unsure:
Thanks IANT. As far as I can tell the edge triggered wiping relay is useful for positive going edges only.
Programming wih Logo is very intuitive however it seems to be missing this one instruction element.
the edge trigger is in the Timer area
you will find the one you want there
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
368
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
298
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,085
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
992
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,052
