Logo! How to change buttons up Logo to normal clicks instead of ESC+ Button Clicks
thewalkerist
May 2021
Izmir
178
Hello i have two problems currently. I have two screens and when i want to scroll between them i just press the down button and it just goes to time instead of next screen. But if i click ESC+down then it changes screen. Is there a way to make it just button clicks instead of ESC+Down?
And another question. I want to have something like a switch. If i click the Left button on my Logo display then i want to energise an output but i dont want it to change after i stop pushing the button.
Can anyone please help me?
I presume the double button depress is to prevent accidental activations.
re. using cursor button as switch.
you can use a latching relay to switch on, then obviosly you need another input to switch off, be that a timer, a counter to use the same button again or another cursor button to switch off.
I include an example.
Left cursor to switch ON, right cursor to switch off.
But now i encountered a new problem. I wanted there to be a 2-step alarm concept.
Now there is a blade and a sensor in my project. If the sensor sees more than 10 seconds i want to put up a notification message that says "Your sensor is running for a long time please check it" and programme will automatically run the blade to cut once than go back into 0 mode again. And after that if the sensor still doesnt go away i want to wait for 10 more seconds and just put out an alarm. How can i do that? can you please help me?
Hi! I have a VFD and a Siemens LOGO. The VFD send the speed feedback 0-10V to my LOGO. The LOGO send the speed setpoint 4-20mA to the VFD. How...
2,568
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
359
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
297
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,082
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
987
