Logo!
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey there.
I am using V7 of Soft Comfort to program a LOGO! I am wondering if there is any function comparable to an "EQU". instruction in other manufacturers PLCs. I am trying to turn on a output based on the position of a count up. Any suggestions?
Thanks for the help in advance.
I may very well be able to. I was simply looking for a way to do this. I would have never thought of using an analog instruction to compare a counter to another value. I will give this a try here in a bit.
Thanks for the advice.
So I believe that this Analog Comparator will do as I want. The issue I have now is trying to connect the block to the rest of the circuit. It gives me the yellow message that says Incompatible Connectors. Is there something I need between my left power bus and the block? I have tried connecting to both the Ax and Ay terminals. I have my sensor: set to NO SENSOR and my refrence is set to my counter and the threshold is a value of one.
Should mention this is an OBA7 device!
Any ideas?
are you working with ladder or with blocks? better use blocks.now for the Incompatible Connectors you can use M blocks as memory bits.
Hello there.
So I have been struggling with this a little. My goal is to turn on output 5 for ten seconds. then off for ten seconds. Then turn on output 6 for ten seconds then off for ten. Then turn on output 7 for ten seconds then off for ten. Repeat!!
I find this very simple in AB but with LOGO I am stuck. As you can see I want to increment counter C004 every time the counters cycle. Based on the position of the counter turn on an output. IE: Count at 1 turn on output 5, count at 2 turn on output 6, count at 3 turn on output 7 then reset the counter. One has mentioned to me to use the Analog comparator but I can't get it to work. If anybody cares to look at my quick program here and criticise it would be greatly appreciated.
Thanks!
Hello Team, I am desperate for some help with an assessment I have as part of a Level 3 general engineering course. I am in a role that is much...
383
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
317
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,090
[Update: fixed a typo in the image.] See the image below, especially the blue-ish annotations. The three rungs ending in output coils -( ) are...
17
1,012
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,059
