benaiahhenry said:
Are you saying there is an automated way to build those kind of diagrams?...
I most certainly am my friend!
You can use the 1492 - Product Configuration Assistant available here...
http://raise.rockwellautomation.com...http://www.rockwellautomation.com/en/e-tools/
At the top, enter the Catalog Number for the Wiring Module such as "1492-IFM40F" and then hit the "Verify" button.
Then select the "I/O Platform" such as "Bulletin 1756 I/O Modules".
Then select the "I/O Module or Base I/O" such as "1756-IB16I: ControlLogix DC Isolated Input, 16 Pts., 10-30V".
If you need any other special features liking fusing, LEDs, etc., then populate the "Wiring System Data", etc.
Then hit the "Accept" button.
On the "Configuration Results" page, on the right hand side, select "Wiring Diagram for I/O Module to IFM Module" and the PDF should open.
The Product Configuration Assistant is session based. So it will time out on you after a short while. Make sure to save what you want before it does or you'll have to start again.
Regards,
George
