Looking for Amphenol parts expert
chop347
Jun 2005
canada
29
I am currently working on a oil rig in Venezuela.
They use seimens plc,s out here.
For there communication they have just regular 2 wire shield # 16 Awg cable just laying on the ground.
Needless to say it doesnt last to long before they start to get com faults all over the place.
I have ordered better cable for them.
http://www.am.pepperl-fuchs.com/pdf/documents/armoredfieldbuscable.pdf
But not exactly 100% on my amphenol numbers. And dont want to get a express air freight and end up with the wrong parts.
My plan is to use a 3 pin soldered pin design with a number 12 body.
The body and pins will be bigger than I need but if I go any smaller they will bust them in a day.
So will start with a panel mount femal wall receptical.
Then need to go thru two in line connections.
Then finish with a panel mound male connection.
Here are the part numbers I do believe I need.
But if some one could double check my numbers would be a HUGE help.
Inline Receptacles.
Male ZREM1012-32P 2 each
Female ZREM1012-32P 2 each
Cable ends
Male ZPEDLJ-1012-32P 1 each
Female ZPEDLJ-1012-32S 1 each
Receptacles
Male ZRLP12-1012-32P 1 each
Female ZPLP12-1012-32S 1 each
Inserts
Male ZP-12-27P 6 each
Female ZP-12-27S 6 each
Insertion Tool TP-201049-1 1 each
Removal Tool TP-201459 1 each
Thanks.
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
399
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
175
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
247
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
182
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
852
