looking for an all-encompassing contact symbol reference
strantor
Sep 2010
katy tx
401
Selector switches often throw me for a loop when I'm looking at drawings. Just as soon as I think I know what the symbols are, I find a new one, or I find out that I've probably been dead wrong all along. I attribute most of this to my own uneducated state, but at the same time, I don't think everybody is on the same page; I think some of the people making the drawings aren't using the proper symbols or there just aren't universally accepted symbols to convey every possible scenario.
Selectors really are (or can be) a lot more complex than one would think; consider if someone handed you a single selector switch with 4 contact blocks attached. By the time you multiply all the different configurations of:
(2 pos, 3pos, 4pos, joystick, etc.)
X
(spring return from right, spring return from left, maintained, etc.)
X
(operator cam style A, operator cam style B, ..., operator cam style Z)
X
(are the contact blocks arranged left>right or up>down?)
X
(contact block #1 style: NO, NC, dual, etc.) (X contact block #2, 3, 4 style)
X
(what SIDE is each contact block mounted on?)
X
(make before break, break before make, etc.)
...there are literally thousands of combinations; one of thousands of possible switches is in your hand.
Now, what if you had to bring a machine back from the boneyard, and someone's gone in and cannibalized the selector switches and contact blocks? Could you reconstruct the switches based on the prints? I don't think I could; at least not without a healthy dose of weeping and gnashing of teeth. So that's what I'm after: a reference that will educate me about selector switch contacts to the point that I could.
A web resource would be nice, but I'm pretty sure if it were out there, I would have found it by now. Everything I've encountered on the web is basic. A book is even better, if you can recommend a good buy. It would be nice if it included American symbols and European also, and maybe even compare/contrast the two. Also if it talked about timer relay contact symbols that would be cool. But I'm getting picky now; I'll take whatever I can get.
Thank you.
Not all-encompassing but, I'd start with the manufacturer's catalogs. They list pages and pages of possible contact/operator configurations and options with the relevant part numbers.
YMMV
Selector switches can be 'Of the Shelf' these are usually readily available and standard.
What is the manufacturer of the other switch gear.
do you have any DWG's that you can post a copy of.
Please include a Photo of the switch location (wiring side)
IF
- the hole is not 22.5 or 30mm dia.
- there are drill holes around the circumference.
Look at
http://www.krausnaimer.com.au/
this an Ausie site but will help you for selections
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
414
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
178
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
249
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
184
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
856
