Looking for Counter/Tachometer Combo Unit
brianafischer
Feb 2004
Hello,
I am looking for a counter and tachometer combination unit. The unit should meet the following specs:
  • 1/600 Hz min frequency (1 cycle every 10 minute)
  • 1 stage preset counter
I called a few distributors, but am coming up dry. Any suggestions?
Do you have an exposed shaft where you can read a target that either exists or you can add?
Or does it need to be strictly something based on vibration or the like?
Looks like Precision Digital's 693 rate/totalizer has a slow speed range: (693 does pulse input)
GATE FUNCTION: PD693​
Slow Pulse rate
Low Gate High Gate Min Pulse Rate(p/s) Min Freq(Hz)
1 3.1 1/3 0.33
1 10.1 1/10 0.01
1 30.1 1/30 0.0333
1 60.1 1/60 0.0167
1 90.1 1/90 0.0111
1 99.1 1/99 0.0101
from table on page 5 their data shwwt LDS692
Dan
I have a limit switch that closes a contact every "x" seconds. I just want to display an accumulated count and the frequency the switch is turning on and off. When the accumulated count equals a set value, a relay output should turn on until a reset button/input is pressed.
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
55
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
151
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
220
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
157
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
810
