Loop controller card
cpriest8
Sep 2005
Defiance, Ohio
Hi, I was wondering if anyone new where to get a manual for an Allen-Bradley 1771-LI Loop controller interface module as AB no longer carries this on its website.
thanks,
Has anyone ever used a stand-alone Dual Loop PID process/temp controller that is programmable to automatically select between two PID loops to...
2,291
Hello guys, I'm in a bit of a dilemma - not very clear on the operation the typical PID controller. Here's the issue: A client has a turbine...
3,790
Hello!! I'm working on a project that requires a Cascaded PID Loop to control solution temperature in a tank with a water jacket. The tank has...
2,399
Does anyone know if there is a multi loop process controller out there that will accept the PV over Ethernet/IP? We have an extrusion machine...
1,551
What are the pro's and con's of doing a psi or temp control pid loop in the processor vs a single loop controller? Which method is best?
3,758
