Lotus 123 Conversion
Tom Jenkins
Apr 2002
Milwaukee, WI
6,301
I have an old file I used to develop some settings. It is in Lotus WK4 format. If someone has the ability to convert it to Excel format, could you please send me a Private Message? Thanks.
This forum is absolutely the greatest. I have gotten the file converted, it had the info I needed, and the updated calculations are on their way to the client.
Thanks to the forum, and thanks to Phil for giving us this great tool.
Tom
Dear, i was looking at the wiring diagram of the auxiliary circuits of PR123 trip unit of ABB MCCB (attached) i was able to depict K51 output...
1,576
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
199
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
hi... i have an issue in s7 300 plc, while we run the machine(in idle there is no fault) , plc cpu goes in SF mode, after restart the power cycle...
117
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
103
