M221 IOScanner and modbus
smiley125
Apr 2014
UK
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
201
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
90
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
122
I am having trouble running the application throught my PLC, tm221me32tk with magelis HMIGTO6310 I have prepared the plc programme, also created...
115
Hello all, I need to build a system that will operate various AC contactors and 'lock' them out for a predertimed time when a set current value...
328
