M340 Modbus communicarion
araxs
Dec 2009
Canada
Dear All
I connect a m340 PLC to Five ATV61 via modbus communication in a daisy chain architecture. Now I have a problem as soon as one of the ATV disconnected from the bus the communication between M340 and other ATV is failed. I do not know how could I fix this problem. I mean exeprt Read_Var and Write_Var function should I use any other funcation to prevent such problem?
Thnk you for your support.
Araxs
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
255
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
320
I'm using M340 (Schneider Electric) as modbus master. It works fine but if there is a disconnection with the slave, it stops working even after...
431
Hello all. I am trying to read out the values from a Carlo Gavazzi EM340 energy analyzer via Modbus communication. The S7-1200 PLC has the CB1241...
29
3,822
Hello, this is a message for specialists in Schneider, I am trying to establish communication in modbus tcp between a schneider M340 (P3420302)...
1,619
