M580 Modbus Read_VAR
haksarfarooq
Mar 2024
Detroit
I'm trying to read modbus data from modbus slave using Read_VAR function. I'm getting an error that my device is not linked to a module.
I have a eH584040 module & eNOC0301.4 module that supports modbus, but neither of them are visible in the model family for some reason.
Thank you for your help
Post screenshots of the configuration, the code, and the error. Attach a ZEF or STA so someone else can have a look at it. I don't do redundancy CPUs or NOC modules but I've successfully used READ_VAR. My understanding is when you have remote IO scanning included in your processor, you'd want to configure that instead of READ_VAR, but I've never had luck with the IO scanning and I don't have any processors on hand that support it. You'd need to look at Schneider's resources.
Looking for some advice on a project. The controller is a BMEP584040. There is a RIO ring with several drops with Quantum I/O. On this ring...
1,143
Hi all, I'm really new to this. I need to export the Modbus register mapping from a Modicon M580 through Control Expert for the registers that...
1,002
Hi Everyone, I'm new to Control Expert but currently I'm working with a project in which I have a Slave M580 PLC that is using a NOM0200 module to...
1,659
I have a project coming up with a M580 cpu with a NOC0301 card. The majority of the comms will be EIP, which I'm familiar with, but I will have...
1,943
I am setting up a system where M580 is Modbus Master data concentrator. I have the Read_Var polling setup, my question is how do you guys handle...
1,680
