Mac 50 and Medoc problem
edgarsky
Apr 2008
Bulacan
Hello, my machine unit was connected to Melsec-A series with Mac 50 connected to A2NCPU, several months I did not operate my machine until the battery inside the A2NCPU was dead and busted already, to cut in short the programmed installed at the PLC was already lost,I placed a new battery and fortunately I have a backup medoc data and successfully re-installed at the PLC, my problem is when I tried to operate the machine some initial testing dosn't work, specifically, the initial test for Infrared lights, I understand to operate this unit I need to put some data to MAC 50, but I think it is not possible beacause my MAC 50 already defective and it is hard to find in the market. What is the alternative solution to solve this problem? is it possible to load the program data came from mac 50 to load directly to A2NCPU? what kind of program do I use? I have a Medoc program & MAC 50 program here. plese help me. Thank you.
Edgar
Do you have the PLC and HMI programming software or simply the PLC and HMI progam itself.
I dont know much about the MAC50 but i would say you need to identify the PLC memory that is used by the MAC50 to provide your 'machine settings'.
Once you have acheived that, you can either rewrite the MAC50 into somthing else (EDesigner / Red Lion G3 / many others) or go into online mode and type sensible values directly into the PLC memory. Of course, if it is product settings it would be unreasonable not to jump straight to a new HMI.
I would suggest printing out the MAC50 program to obtain all the configuration data. Post the MAC50 program here if you dont have an editor package and someone is bound to help you
Cheers
Hi, I have been trying to run drive via Sysmac studio. I can ping the drive. I can see the logic bits going on/off as per command. But, drive is...
21
570
Good morning to everyone on the forum and happy new year. I'm trying to use the following functions in sysmac studio, because I need to enable one...
327
So, here's probably a silly one that I hope someone here knows. I am working with a SYSMAC NA5 HMI. (First time doing anything with Omron.) What...
511
Good morning everyone, I'm having difficulty using the "sin" and "cos" functions in sysmac, in particular the results of the functions are not...
1,155
looking for the the MAC address for this PLC, I count find it in the front or at any part of the PLC itself. connected to the PLC by USB, showing...
1,764
