Magelis HMI & GE Fanuc PLC
Schtiel
Oct 2006
West
92
Is it possible to connect Magelis panel to GE Fanuc PLC using Ethernet? What is necessary to do this? Are there any additional drivers for Vijeo Designer or something like that?
Magelis XBTG to GE
If your Magelis is like the ones I've used in the US, it has a yellow/green sticker on the back that states that you can't use it with a GE PLC or GE Protocols. I've been told, however, by my Schneider Electric guy that there are drivers available, but you have to push a bit to get them to release a copy of them to you.
The Magelis multi-vendor drivers used to be sold separately. You should contact Schneider to buy them. But last time I worked with Magelis (going back about 5 years) the multi-vendor drivers were all serial, only Ethernet drivers were the Modbus/TCP ones.
Well, I contacted Russian Schneider representatives, they answered that it's impossible :(
Anybody has experience in connecting GE Fanuc PLC and Magelis HMI via Ethernet?
As I said in my post, there were no Magelis drivers for that. Only serial communications to anyone other than Modicon equipment.
If they told you it cannot be done, why are you asking the question again?
Well, once they gave me a similar answer but I've found the solution on this forum. That's why I am hesitating...
Question: Does Vijeo Designer V4.5 support GE Drivers?
Answer: The GE Drivers is provided as an option to Vijeo-Designer V4.5 and an upgrade reference will need to be purchased.
To enter the Upgrade Reference, the user must register Vijeo-Designer V4.5 first. Once the software is registered, there an Upgrade button available in the "About" dialog box. The user must press this button and enter the Upgrade Reference number.
Source is here.
Has anybody used these drivers?
Answer The GE Drivers is provided as an option to Vijeo-Designer V4.5 and an upgrade reference will need to be purchased.
http://download.telemecanique.com/8...83CE12CEAD1C12573940015228C?OpenDocument&L=EN
What is the upgrade reference number for GE Drivers?
Good morning friends. . We are having a problem with one of our machines that have two HMI consoles connected to the same network. They have...
1,132
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,646
The above HMI does not power up and is located on a Caribbean island. This started after a 24 hour power outage. It has power now but the screen...
1,213
I have an M241 connected in Ethernet to a HMIS5T panel and I can't get them to communicate I'm using Machine Expert 1.2 On the controller the...
1,818
We're an industrial machinery merchant and it behooves us to try to get uploads from all the various control systems that pass through our doors...
4,809
